How to know the quality of imagem?
Juliano.Cavedon
Post by Juliano.Cavedon »
Hi
There are a way to know the quality of the picture in relation of the size it will be print?
It´s possible to give the size of the picture and the XnView inform if the quality of the file comparing with the exif information?
Ex. I´d like to print 10x15cm and the picture is minor than 1 megapixel, than the quality will be poor.
Re: How to know the quality of imagem?
Juliano.Cavedon wrote:Hi
If you know the DPI, you can have the minimum size in pixels of your picture for a good quality...
