My first post here.....hope I don't ask a dumb question. Lol
I have a "bmp" animated image in "My Pictures" folder. How would I change it to a "gif" and retain the animation?
Many thanks......nice to meet you all. I plan on being a "regular".
Duane
Changing format from animated bmp to gif
Re: Changing format from bmp to gif
We'll let you knowduane wrote:My first post here.....hope I don't ask a dumb question.
For all I know, the 'BMP' format doesn't support animation. So I assume that your image has the extension '.bmp', but in fact is in GIF format. It's in fact important to understand that the extension of a file and the contents/formats typically match, but this is not a must.duane wrote:I have a "bmp" animated image in "My Pictures" folder. How would I change it to a "gif" and retain the animation?
To find out, just open the 'Properties' dialog by selecting the image in the browser and then opening the properties using menu 'Edit->Properties' (or CTRL + E).
It's nice to see the same people visiting by every no and then.duane wrote:Many thanks......nice to meet you all. I plan on being a "regular".
Greetings,
Helmut
There is a method for animated bmps, but as you said this is an animated gifhelmut wrote:For all I know, the 'BMP' format doesn't support animation. So I assume that your image has the extension '.bmp', but in fact is in GIF format. It's in fact important to understand that the extension of a file and the contents/formats typically match, but this is not a must.
The problem is caused by your Web browser (I assume it's MS Internet Explorer):Anonymous wrote:Helmut......here is the image that I saved. It was animated where I got it, but changed to BMP in MY Pictures folder (no animation).
When right clicking on your image and choosing 'Save image..' in the context menu, the image is saved as Bitmap. BMP format does not support animation - Internet Explorer saves only the first frame of the image and thus destroys the animated GIF.
I've tried a bit to find a way to save the animated GIF. What you could do is save the whole web page (File->Save as...), the animated GIF will be amongst the save files. Or use a software like HTTrack which can download webpages or parts of it from the web.
Perhaps there's a better way to save animated GIFs from a web page...
