i would like to exclude cr2 files (Canon 5D Raw File). The Box for cr2 Files, under Associations, is not checked, but Xnview still tries to open them. I have my 5D setup to save both Raw and a small jpg, and when i go through my CF Card i would like Xnview to only show the jpgs. So, how do I exclude it, that it works ?
How to exclude cr2 ?
Re: How to exclude cr2 ?
so you must set option/Browser/Item displayedp5freak wrote:Hello,
zorglups
I'm using version 1.90.2 and can't find such an option.xnview wrote: so you must set option/Browser/Item displayed
Can you help ?
I would like as well to ignore those big RAW files (NEF)
Last field
—> zorglups
Hello
• An accuracy : Excude is the last field at the bottom to enter the extension, the one above is Include,
and captions to show this are pretty missing in that dialogue !
- I've added captions in French because it's quite confusing…
KR
zorglups
