<Moderator's note: Please do not cross-post the same message in several forum. Other duplicates have been removed>.
am using .cab to install the software on my wm5, after trying to uninstall it still there, any clue
no way to uninstall
kts01
no way to uninstall
sorry i mean no way to uninstall the software after i installed in to my wm5 using .cab
Re: no way to uninstall
How do you try to uninstall it?kts01 wrote:sorry i mean no way to uninstall the software after i installed in to my wm5 using .cab
