pixal size is SO Awkward
make contact sheet
nordic
make contact sheet
can we have the sizing for the contact sheet in inches or cm/mm
Troken
Troken
Pierre, I'd like to adress this request again, because the current solution is not intuitive at all. If I want to make a contact sheet in the A4 format, I have to count the pixels myself, instead of having some presets. Or at least have some options to set the size in cm or mm.
What do you think? Anyones opinion about it?
Yes, but in next 1.90, you have a better way to print contact sheet...Troken wrote:Pierre, I'd like to adress this request again, because the current solution is not intuitive at all. If I want to make a contact sheet in the A4 format, I have to count the pixels myself, instead of having some presets. Or at least have some options to set the size in cm or mm.
Troken
