Is MENU View>Thumbnails Size>presets needed?
Olivier_G
Post by Olivier_G »
Shouldn't 'Thumbnails Size' be available under Options only, instead of being listed with all those presets in the Menu>View?
(I extensively use the Thumbnails Cache and therefore seldom modify Thumbnails size)
Olivier
Re: Is MENU View>Thumbnails Size>presets needed?
Olivier_G wrote:Shouldn't 'Thumbnails Size' be available under Options only, instead of being listed with all those presets in the Menu>View?
Often, it's very simple to use menu if you want classic thumbnail size...
Olivier_G
Post by Olivier_G »
xnview wrote:Often, it's very simple to use menu if you want classic thumbnail size...
Ok. I understand (especially with small images and no cache). I just wanted to check that...
Thank you for your answers, Pierre.
Edit: Closed issue.
Olivier
