How to install GFLAx on Windows server?
ganton
Post by ganton »
I have looked at the XnView and GFL SDK help, and have not found info on how to install the Windows (ASP-enabled) version of GFLAx on a Web host. I am on a Windows server, shared hosting, so I cannot register dll files. I am pretty certain that they're running Windows Server 2003, IIS, because the email component is CDO, not CDONTS. They also have ASP Mail on the server. I can run other ASP and VBScript apps. I can see default "_db_import", "db", "asp_client", and "logs" folders at my login folder level. Can anyone give me the step-by-step of getting GFLAx installed?
ganton
Post by ganton »
A minor correction to my previous post: One of the folders I see at my login folder level is "aspnet_client", not "asp_client". The others mentioned were correct.
Re: How to install GFLAx on Windows server?
ganton wrote:I have looked at the XnView and GFL SDK help, and have not found info on how to install the Windows (ASP-enabled) version of GFLAx on a Web host. I am on a Windows server, shared hosting, so I cannot register dll files. I am pretty certain that they're running Windows Server 2003, IIS, because the email component is CDO, not CDONTS. They also have ASP Mail on the server. I can run other ASP and VBScript apps. I can see default "_db_import", "db", "asp_client", and "logs" folders at my login folder level. Can anyone give me the step-by-step of getting GFLAx installed?
The only way to install GFLAX is to register it
