Add copyright under image ?
antisa
Post by antisa »
Hello
How can i do to add some text copyright under each picture ?
I know how to add some text in the bottom center, but not UNDER each image ?
Thanks for this very very good software !!
Isa
On vaccum
:) Hello, welcome aboard !
• And where do you write it? I mean : on which support ?
You can't write outside the image ! :P
- So, you must prior enlarge the canvas using Image menu >> Canvas size.
1. Untick [ ] Keep the ratio
2. Increase the height by n… pixels, according to the text you wish to add.
3. Click the position (the array of small buttons) as UP - centred
You get an empty area at the bottom
4. "Add text…" and place it like you need in that empty area.
• I tested this, it works.
:mrgreen: Kind regards,
antisa
thanks
Post by antisa »
Hello from france :-)
I asked this because the CopyrightLeft software has this option "under".
I will do like you say !
Thanks !!
antisa
Post by antisa »
Je suis de Bordeaux aussi !!!! Incroyable LOL
Ring up !
:D Ah ah ! The next time, just ring up me !
- Indeed, specialized softs can perform these operations as one go…
- But I'm not sure that they be free of charge ;)
BTW : There is a French section here, it's more “comfortable”, and our Dear Author Pierre reads it as well…
:mrgreen: KR, Cordialement,
black ?
Post by Guest »
Hello Clo
I have done like you say but i have a black line but i choose the white color...
How to have the white color ?
I clic on "taille du canevas", is it the good menu ?
Thank you :-)
PM-PM-PM
:) Hello Isa : Forgot to loggin ?
Please, check your private messages… ;)
:mrgreen: KR
