deluxe viewer contact sheet tabs How?
Post by Guest »
when I create contact sheets this free viewer it displays the pages with tabs which is very cool. How do i display tabs if I use the deluxe viewer. It just opens up a bunch of individual windows and clutters up the screen when I make contact sheet.
Re: deluxe viewer contact sheet tabs How?
Anonymous wrote:when I create contact sheets this free viewer it displays the pages with tabs which is very cool. How do i display tabs if I use the deluxe viewer. It just opens up a bunch of individual windows and clutters up the screen when I make contact sheet.
Deluxe version is not more supported, sorry...
The current version of XnView DeLuxe has no support for tabs and development of XnView DeLuxe has been stopped. In "Windows" menu you will find the list of opened windows, perhaps it helps.
