Help Xnview quit working I'm screwed
Post by Guest »
I have been using xnview to create contact sheets and it has been working great up until yesterday. I am using 1.82.4 with windows XP.
I tried to create a 30 page contact sheet yesterday and it froze up during page 24 and it has never been the same since.
When I open xnview since it shows binary strings in the window at the bottom where i could click on an icon and preview the image before. Also all the image I am using are .eps
When I select an icon the program will now freeze up(not responding. I hit ctrl/alt/del and it shows 100% CPU usage. Also there is no spyware on my computer to slow it down. When I close the program I get an error message.
szAppName:xnview.exe szmodName: hungapp
szModVer: 0.0.0.0 offset:00000000
szAppVer1.82.0.0
the following files will be included in error report
\Locals`1\temp\WER5B70.tmp.dir00\xnview.exe.mdmp
\Locals`1\temp\WER5B70.tmp.dir00\appcompat.txt
I have uninstalled xnview and downloaded it again and am still having the same problem. What went wrong? How do I fix this? Help!!
Re: Help Xnview quit working I'm screwed
Anonymous wrote:I have been using xnview to create contact sheets and it has been working great up until yesterday. I am using 1.82.4 with windows XP.
szAppVer1.82.0.0
Strange, try to remove xnview.ini
Post by Guest »
how do I remove xnview.ini file where is it located
Anonymous wrote:how do I remove xnview.ini file where is it located
In windows folder, or in xnview app folder
