Negative increment for multiple rename function
Rolf Wiegand
Post by Rolf Wiegand »
I use a HP scanjet 5590 with duplexing auto document feeder. When the paper of the originals is too light or too heavy the duplexing does not work properly. A workaround is to scan both sides separately. Then it would be a very great help to have a negative increment of -1 or -2 for use with the multiple rename function to rename the back sides. By now I have to rename every single file manually.
Best regards
Rolf
Dreamer
Post by Dreamer »
Could you explain please? Some example, how it should look before/after. You can use "<Filename> -##" - result will be "file -01.jpg", "file -02.jpg"... :?
Dreamer
Rolf Wiegand
Example
if I scan a batch of paper without duplex-feature (because paper weight is too heavy) I get in the first run pages 1, 3, 5, ..... 49. These I scan with option "uneven pages" and increment 2. Then I flip the batch of papers to scan the backsides. Then I get the pages 50, 48, 46, 44,....2 . Therefor I would appreciate the possibility to start the scan with page 50 an an increment of -2 (i.e. a decrement). A workaround can be to scan these pages in normal way and use multiple rename to rename the files starting with 50 and "incrementing" by -2.
By now I do the rename by hand, which is very boring because of the amount of pages I am scanning.
Dreamer
Post by Dreamer »
Try "Step: 2".
Dreamer
Rolf Wiegand
Step 2
Hi Dreamer,
step 2 will work only for the front pages of the batch of papers. If you flip the batch to scan the back pages you get the sort order descendent (just take a journal and look at the sort order of the pages when you look from the front or from the back).
atx4us
Re: Negative increment for multiple rename function
Post by atx4us »
I have the same need for the negative increment (step) for the multiple rename function. Can you please implement this functionality? I have to use a different rename tool right now to accomplish this task because it is much too tedious to rename hundreds (or even thousands) of files manually.
Drahken
Post by Drahken »
So... As I understand this; You have a bunch of files in reverse order & want to rename them in proper order? So that 1, 2, 3, 4 becomes 50, 49, 47, 46 (or vice-versa)?
The solution to that is simple: On the batch rename dialog, click the "sort by" drop down and set it to "name (descending)". This will reverse the order of the numbering.
^ Note how the order of the original files is reversed, while the order of the new names remains the same, thus renumbering the files in reverse order.
atx4us
Post by atx4us »
That's a really cool tip! Thanks a lot for the hint. But, for most users, it will be more intuitive to use a negative increment value.
Drahken
Post by Drahken »
To me, changing the order of the files in the list is much more intuitive. In fact, it took me several re-readings of the posts in this thread to grasp what you & the original poster (from 6 years ago) were trying to do.
