Show info on full screen: Bottom placement, formatting
fahrplan
Post by fahrplan »
Hello!
GREAT! The Show IPTC on fullscreen function now seems to work fine for me.
The only thing that does not seem to work is to place the info text at the bottom (doesn't matter, if left, center oder right). This leads to no info being shown at the whole screen.
Info at the top or vertical center works fine, and with the fix for more that 512 letters it's really cool to use with slide shows.
Small suggestion:
Perhaps more guys like me would love to format the info displayed a little more comfortable, especially to format a headline and a description text individually.
Cheers and thanks for great work as everytime.
fahrplan
Re: Show info on full screen minor problem and suggestion
fahrplan wrote:The only thing that does not seem to work is to place the info text at the bottom (doesn't matter, if left, center oder right). This leads to no info being showed at the whole screen.
Ok, a :bugconfirmed:
