New menu "View > Explorer pane"
In XnView 1.90 browser there are new menu items:
View >
    Explorer pane >
       Folders
       Favorites
       Show
       Use tab
    Preview >
       Preview
       Use tab
Instead, I suggest the following menu structure:
View >
    Tree pane >
       Show
       Use tabs
       Folders
       Favorites
    Preview >
       Show
       Use tabs
       Preview
       Histogram
       Properties
       EXIF
Reasons for the changes are:
- Inconsistent naming
"Show" and "Preview" are used for showing the panes, this is inconsistent. It should say "Show" in both cases or "Explorer" and "Preview", respectively.
- Menu items for choosing tabs: Missing
There are menu items "Folder" and "Favorites" for choosing the tab in the Explorer pane, but there are no such menu items in the Preview sub menu.
- Menu items for choosing tabs: Position
Instead of listing the menu items for switching tabs at the top, I'd list them at the bottom. Advantage is that the menu items at the top are the same for both submenus.
- Mnemonics and/or shortcuts
I doubt that the menu items for choosing tabs are often used via mouse. For this reason we should provide shortcuts (Ctrl+<key>) and/or mnemonics. (Not so sure about this one).
- Explorer pane vs. Tree pane
When using the term "Explorer" you might run into licence problems and trials with a large software company. Also, the Explorer pane does not really allow for exploring, it's the combination of folder tree/favourites and file list. (Not so sure about this one, either).
- Use tab*s*
While we are at it: A minor bug in the translation (I'll report it here for the alpha but will repeat it for the beta). It should say "Use tabs" rather than "Use tab".
JohnFredC
Post by JohnFredC »
I personally don't care for either "Explorer pane" or "Tree pane" nomenclature.
How about this:
View >
    Navigator >
       Show
       Use tabs
       Folder Tree
       Favorites
"Navigator" would not conflict with functionality offered by possible/future subpanels, such as a new subpanel to filter the file/thumbnail list based on Tags/Categories.
John
klumy
Post by klumy »
I think
Folder Tree
Favorites
should be removed from the menu. Because these commands are easier to access via the normal interface than with the menu commands.
XNView 1.91.5
Windows XP SP3
klumy wrote:I think
Folder Tree
Favorites
Yes and no: I don't like the two menu items, either. In "View > Preview >" menu there will be even four of them.
But these menu items are needed in case you have deactivated "Use tabs", they will be the only way to switch inbetween panels.
Perhaps these menu items could be in quotes to indicate that these are labels of panels (Not quite sure whether this would make things clearer):
View >
    Tree pane >
       Show
       Use tabs
       Folders
       Favorites
    Preview >
       Show
       Use tabs
       'Preview'
       'Histogram'
       'Properties'
       'EXIF'
Adding a prefix like "Switch to" would be too heavy, I think.
JohnFredC wrote:...
How about this:
View >
    Navigator >
       Show
       Use tabs
       Folder Tree
       Favorites
"Explorer" or "Navigator", I think both are good. The user explores or navigates in the folder structure, favourites, or what ever.
Olivier_G
Re: New menu "View > Explorer pane"
Post by Olivier_G »
All previous suggestions have been implemented, there is only the Preview selector (in red) to implement:
Preview>
- Show
- Use tabs
- Preview
*Properties
- Histogram
- EXIF
- IPTC
Olivier
Olivier_G
Post by Olivier_G »
Olivier_G wrote:- Preview
*Properties
- Histogram
- IPTC
- EXIF
- XMP
Implemented in Beta 6.
Note: I would prefer "EXIF" just before "IPTC" because it's more frequent and IPTC & XMP are quite close.
-> Confirmed... as the fix should be easy.
Same order should apply to Preview tabs too, ie: Preview|Properties|Histogram|EXIF|IPTC|XMP.
Olivier
From what I can see, all changes have been made in RC1.
Now that I see what the menus look like, I'd suggest to change the order of the menu items, again. Currently we have:
View >
    Tree pane >
       Show
       Use tabs
       Folders
       Favorites
    Preview >
       Show
       Use tabs
       Preview
       Histogram
       Properties
       EXIF
The menu items most often used are the ones for switching the tabs. The other ones are settings which are not changed that often. The menu items most often used should be listed first, so I suggest:
View >
    Tree pane >
       Folders
       Favorites
       Categories
       Show
       Use tabs
    Preview >
       Preview
       Histogram
       Properties
       EXIF
       Show
       Use tabs
If possible I'd like to see this both briefly discussed and implemented in 1.90.
JohnFredC
Post by JohnFredC »
In addition, the reuse of the word "Preview" might be a little confusing.
Maybe the word "Image" or words "Image Preview" would be better:
Preview >
       Show
       Use tabs
       Histogram
       Properties
       EXIF
John
JohnFredC wrote:...
Preview > Preview is really a bit strange - but not to bad.
Perhaps "Preview pane" > Preview would be better. "Pane" is short and lightweight in English, but translators in other language might have long translations. E.g. in German it could be "Vorschaubereich". So I think it's better to stick to "Preview".
JohnFredC
Post by JohnFredC »
Yet another example where the TC approach to menu configuration would make this a non-issue for XnView users. TC uses a menu definition in a text file that users can edit to make the menus anything they wish.
IMHO, Pierre's efforts would be better spent in creating generic methods and structures (such as a mechanism that would display a menu from a text file) than in trying to decide what menu sequence is optimum (no such thing!) and then hard-coding it.
Once the generic method is completed, menu definition and maintenance becomes a trivial effort.
Of course, such a schema requires a "cmd_" command for every single program action. I know that is a big task.
A worthy goal for some future version, anyway.
John
Danny
Post by Danny »
I don't like using the main menu at all, no matter what program. I'm a fan of context menus.
P.S.: Wrong forum, this is no bug.
Get the bugs fixed, THEN start adding features. It sucks, but someone has to do it.
ouistiti
Post by ouistiti »
:arrow: JohnFredC
I agree totally, menus as texts ARE the only good solution…
Paul (TC user for ages)
1,77245385090552...
I still would like to see the order of the menus changed (see above).
This topic is very much in discussion stage, so as Danny suggested I move it back to Info & Feedback.
-> Info & Feedback
In RC2 Pierre has changed again the order of the menu items as proposed above. Now, the menu items for switching the tabs are listed. I think it's good this way. Thanks, Pierre!
