SageThumbs - Thumbnail image shell extension
Plug-ins, add-ons, skins, icons, templates and other downloads. Contributions are welcome.
ckit
Post by ckit »
Nikolay Raspopov wrote:
JohnFredC wrote:Is it possible to "unload" SageThumbs from the context menu without rebooting?
Explorer lock it inside for about 10 min after last use. Its "Greatest Microsoft Perfomance Optimization". I hope rebooting is the fastest way...
No, logging off and back on again is the fastest way. Also if you run a dial-in server like I do, I have a registry tweak that will keep your dial-in connections when logging out and in.
Another tip, when uninstalling and upgrading shell extensions make sure ALL file managers (Windows Explorer or xplorer2) are closed Before you do anything and use Start -> Run to install the newer version.
Nikolay Raspopov
Post by Nikolay Raspopov »
ckit wrote:No, logging off and back on again is the fastest way
I doubt. During relogging MOVEFILE_DELAY_UNTIL_REBOOT files are not processing and auto-logon not working. My WinXP rebooting faster than "logging-off-password-typing-logging-on".
ckit
Post by ckit »
Strange, it works for me on Win2k really well.
Post by Guest »
PNG and TGA thumbnails is not showing in SageThumbs, can anyone help?
please :)
Nikolay Raspopov
SageThumbs 1.0.0.11 released
SageThumbs 1.0.0.11 released!
Try new version and if bug not gone than send me (ryo-oh-ki@narod.ru) that problems 1 png and 1 tga files.
Please check my program labels and text documentation for spelling errors... :(
Dani
Possible bug with thumbnails of TGA and PNG formats
Post by Dani »
I installed SageThumbs 1.0.0.11, i make a clean install, removed the version 1.0.0.10, rebooted and then installed the new one, but the problem still there, i can't see thumbnails fo PNG and TGA but can see all other supported formats.
I sent you a screenchot and 2 sampler files as you ask me one PNG and one TGA. I hope it can help.
Nikolay Raspopov
SageThumbs 1.0.0.12 Released
SageThumbs 1.0.0.12 released
+ Fixed one stupid registry bug... :|
Dani
Post by Dani »
Thank you, i will give i try :D
DarkPunk
Post by DarkPunk »
Very usefull! Thank you! :mrgreen:
Few suggestion for new version: multi conversion (if more than one files selected), more types of file in conversion (png, etc.), options in conversion (level of compression etc.).
Great Job!
Dani
Post by Dani »
Hi, sorry for take too long but i tried the latest version (1.0.0.12) but now i can't see PSD thumbnails.
BUT i installed the version 1.0.0.9 and work woth all formats, only the versions 1.0.0.10, 1.0.0.11 and 1.0.0.12 cause this thumbnails issues here.
PC:
P4 3.0 GHz
Memory 1 GHz DDR
Video card ATI All-In-Wonder 9800 Pro 128 MB
WinXP Pro SP2
I hope it can help.
SeaMaiden
Post by SeaMaiden »
When will a new version of SageThumbs be available? I have never installed this plugin since it still appears to have some reported bugs and because XnShellEx 1.2 is already installed.
What's the difference between SageThumbs and XnShellEx? They both have thumbnail preview features. Can both be installed at the same time?
Windows 11 (64-bit), Android 12, XnViewMP 1.5.0, XnResize 1.10, XnShell 4.16
** XnView ROCKS **
Nikolay Raspopov
SeaMaiden wrote:When will a new version of SageThumbs be available? I have never installed this plugin since it still appears to have some reported bugs and because XnShellEx 1.2 is already installed.
Wherefore? What bugs?
SageThumbs is more powerfull than XnShellEx. It makes Windows Explorer looks like XnView. :-)
SeaMaiden
Post by SeaMaiden »
Please answer a few questions.
1. SageThumbs file properties state its language is Russian. Does that mean the file and menu options are in Russian rather than English, or is there an English version of the file?
2. Can SageThumbs and XnShellEx be installed at the same time, or must XnShellEx be uninstalled before installing SageThumbs?
3. Are there any issues with Windows XP SP2?
4. Are there still issues with uninstalling the plugin, or have all those been fixed?
From this thread, I did learn that to install this, all Explorer and Internet Explorer windows should be closed, and the plugin should be installed by Start - Run. The bugs mentioned in the posts before mine mentioned uninstall problems and some thumbnails don't display. No mention here of what happens if you install SageThumbs when XnShellEx is already installed, so I had to ask.
** XnView ROCKS **
Nikolay Raspopov
SeaMaiden wrote:1. SageThumbs file properties state its language is Russian. Does that mean the file and menu options are in Russian rather than English, or is there an English version of the file?
Single file contains russian and english translations. Its depends on windows default language.
SeaMaiden wrote:2. Can SageThumbs and XnShellEx be installed at the same time, or must XnShellEx be uninstalled before installing SageThumbs?
Its possible but looks funny.
SeaMaiden wrote:3. Are there any issues with Windows XP SP2?
Nop. Its a system where SageThumbs was born.
SeaMaiden wrote:4. Are there still issues with uninstalling the plugin, or have all those been fixed?
I hope it fixed. :twisted:
SeaMaiden wrote:From this thread, I did learn that to install this, all Explorer and Internet Explorer windows should be closed, and the plugin should be installed by Start - Run.
Nop. Install like other normal windows programms.
SeaMaiden wrote:The bugs mentioned in the posts before mine mentioned uninstall problems and some thumbnails don't display.
Please send me that undisplayable zipped problem file if any.
Post by Guest »
i noticed that this dl is broken...
here is a working one :
http://throb.net/sagethumbs_1.0.0.12.exe
rob
