SageThumbs - Thumbnail image shell extension
Re: SageThumbs 1.0.0.12 - Thumbnail image shell extension
Sorry I didn't noticed. I was doing it in a test virtual machine with lot of thums extensions (looking for the best)
I have a question / suggestion. Does it replace the build in thumbs processor from XP for ico/png/jpg? I would like the ico thumbs to be generated from the largest exisiting icon in the ico file. Or looking first for 48 then for 32 then for 16. It's funny to have small icons in thumbs view.
Would like support for cpt /cdr (corel files); svg (open format...firefox can render them nice); and probably dwg (autocad)...at least those that are based on extracting bitmap thumbs inside the vector file
Is it possible to disable the shell menu feature for SageThumbs and still leave it registered as the thumbnail handler for windows explorer (really like the fact that it provides thumbnail images in windows explorers thumbnail view for so many formats that previously were unsupported or marginally supported)?
Failing that it would be very nice if the thumbnail preview for SageThumbs (in the context menu itself) could be moved into a submenu (I already have a SageThumbs submenu that appears so why not give people the option of placing the preview in there instead of in the main body of the context menu) that way when I right click on an image file in order to perform some other operations I don't have it shoving all of my other context menu items all over the place making it hard to get to some of them (like many people I have a number of programs installed that register themselves in the context menu and as such my context menu is extremely large already, having the preview show up right there just makes matters worse).
BTW if the author of XnView happens to read this the same ability would be much appreciated in the XnView Shell Extension as well.
Thank you,
bartman2589
Thank you,
bartman2589
Hello!
Question to author:
Can you add to plugin one menu - Print with xNView?
as it doing with ACDSee?
И по русски:
в асидиси в контекстном меню есть пункт - напечатать при помощи асидиси.
если много картинок выбрал - тоже пункт сохраняется.
а в вашем плагине и в шелл-экстеншнах нету((
сложно это реализовать?
или, может быть, подскажете, как самостоятельно написать такое расширение?))
Question to author:
И по русски:
Ask XnView author about adding "print" command to XnView command-line options.remlo wrote:Can you add to plugin one menu - Print with xNView?
Попроси автора XnView чтобы он добавил опцию "печать" в коммандную строчку XnView.remlo wrote:в асидиси в контекстном меню есть пункт - напечатать при помощи асидиси.
Re: SageThumbs 2.0.0.1 - Thumbnail image shell extension
thumbnails .max файлов не отображаются не в explorer не при right click
Можно это исправить?
(файлы для тестов : http://veda3d.com/img/maxfiles_4xnview.rar)
edit: в остальном все прекрасно работает
Royal Ghost | http://veda3d.com
Could support for the vtf format be added, please?
I saw, that this format was added to XNView with the last version.
Re: SageThumbs 1.0.0.10 released.
thank you so muchNikolay Raspopov wrote:SageThumbs 1.0.0.10 released.
+ Fixed installation procedure
+ Fixed shell registration
+ Fixed "experimental ColumnHandler support in 1.0.0.9" bug
+ Fixed "duplicate context menu item insertion in Explorer File menu" bug
+ Fixed "missing uppercase file extensions" bug
+ Fixed "right-click double selection" bug
+ Now GFL thread-safe (more stable)
+ Added extensions cache for performance
+ Added Options dialog shortcut in Start Menu and Control Panel
+ Added handled extension selection in Options dialog
may i ask a question?
i posted a similar question here
i would like a extension to see in the explorer the raw thumbs ,like the jpg , for windows 7 and xp
i know there for example the canon codec for w7 but are really very slow
can i use the program to see in windows 7 or windows xp sp2/3 in the explorer the thumbs of my raw files ?
thanks a lot!!!
Re: Updated d/l link and problem w/ forum site
is dead again ! sadlyJohn wrote:Absolutely awesome tool - have just started using it. Two things:
1. The download links didn't work; the "official" link comes up 403/forbidden, and the other link 404s. The link I found which works is this one:
http://rapidshare.de/files/26843867/SageThumbs.rar.html
2. Somehow, this forum site initially was displaying in English, and at some point it suddenly started displaying in Spanish. I'm not sure how this happened (I don't think I clicked on anything to do this, and I don't even see a Spanish version - just German and French in addition to English), but deleting the cookie for the site fixed the problem.
The download link for SageThumbs provided in the initial post works for me without problem. The page is in russian, though.drugo wrote:... is dead again ! sadly![]()
I have a question: The readme says, that support for other image format types could be added by using the XNView plug-ins, but sadly I am unable to get it work.
I installed the full XNView version with the plug-in set, I tried extracting the content of the plug-ins package into the SageThumbs-folder, but nothing...
I am thankful for every help!
What image format?
VTF for example
i have a question tooNikolay Raspopov wrote:What image format?
to see the thumbs in explorer , should i have xnview installed or the portable version is enought?
thanks !
Still no response?
Send me a small sample vtf-file.
