Not, cause embed thumbnails are very ugly especially after resizing for required size. But I never met raw-files with embed thumbnails.xnview wrote:Do you use embedded thumbnail flag?
SageThumbs - Thumbnail image shell extension
Nikolay Raspopov
Re: SageThumbs 2.0.0.1 - Thumbnail image shell extension
For RAW, you can use embedded thumbnail flag and the embedded picture will be loaded...Nikolay Raspopov wrote:Not, cause embed thumbnails are very ugly especially after resizing for required size. But I never met raw-files with embed thumbnails.xnview wrote:Do you use embedded thumbnail flag?
drugo
canon raw filexnview wrote:Which RAW?drugo wrote:on my w7 it's slow to make thumbnails of my raw files
is there a way to speed up ?
how can i do it with sagethumbs, i mean enable embedded thumbnails flag?Do you use embedded thumbnail flag?
Could you send me a sample?drugo wrote: canon raw file
It's for Nikolayhow can i do it with sagethumbs, i mean enable embedded thumbnails flag?Do you use embedded thumbnail flag?
Brandon
Would it possible to install the shell extension manually?
Also it would be nice to have the ability to convert images to tga (context menu).
drugo
for w7 for example there is a codec to have the raw thumbnails in exlorerNikolay Raspopov wrote:Yes, buy faster hard disk drive, moreover I suggest RAID-0 using.drugo wrote:on my w7 it's slow to make thumbnails of my raw files
for xp there is nothing updated
could possibly to have a shell integration to have raw thumbnails in explorer ? like 1d mark IV or 7d raw files?
it would be great have a option to use the embeded image inside the raw ,yes i know they are ugly but it perform a lot more faster
thanks a lot
drugo
HiNikolay Raspopov wrote:Not, cause embed thumbnails are very ugly especially after resizing for required size. But I never met raw-files with embed thumbnails.xnview wrote:Do you use embedded thumbnail flag?
Nikolay
may i ask a question ?
the program is super cool
but it does not support for example the canon 7d raw files
can you please check this file -> http://216.18.212.226/PRODS/E7D/FULLRES ... I00100.CR2
it's a 7d raw file
i get a strange immage
thanks
cheers
Nikolay Raspopov
Fixed since version 2.0.0.2.drugo wrote:it's a 7d raw file
Kilmatead
Re: SageThumbs 2.0.0.2 - Thumbnail image shell extension
Hmm, as of 2.0.0.2 (x64), XCF files which don't have a fixed 1:1 aspect ratio create stretched thumbnails in explorer, though display properly within the context menu extension.
They also appear solid black when first-created/updated - one has to navigate away from the folder then back to get the new thumbnails.
Neither of these problems occurred in 2.0.0.1
Win7 x64
Win7 x64
Nikolay Raspopov
Ok. Send me such problem file.
Nikolay Raspopov
Re: SageThumbs 2.0.0.3 - Thumbnail image shell extension
Bumped version 2.0.0.3.
FTA
Hi, Nik, the best project
. Just some feedback about the new version. There is some problem in refreshing the thumbnails. Check that screen:
This occurs when refreshing the window, or just get back to that folder(the loading bar is completed). It happens pretty often.
Nikolay Raspopov
Re: SageThumbs 2.0.0.5 - Thumbnail image shell extension
Bumped version 2.0.0.5. Many improvements and fixes.
Anarkhya
Re: SageThumbs 2.0.0.8 - Thumbnail image shell extension
Thanks for your neat piece of code (and +1 for the black thumbnails fix on win7). Having the possibility to immediately browse my .dds texture directories is essential, I simply couldn't go back.
xenio
PDF icon without thumbs
I have not thumbs preview for the PDF icons...
The checkbox options for PDF is flagged
I have Acrobat Reader X installed
Sagethumbs version 2.0.0.8
Windows 7 Pro 64bit
Any suggestion?
Thanks
Windows 7 Pro 64bit
Any suggestion?
Thanks
