1. In "Interface->Recent lists".
Uncheck "Show Most Recently Used Files in File menu", the "Show Most Recently Used Files in submenu" is grayed.
But when I reopen the option window again, it is not grayed and is enabled.
It should still be grayed (disabled).
2. In "Browser->File List->Items displayed".
There are two "Custom files" at the bottom. There should be only one, right?
3. In "Browser->Thumbnail->Appearance".
The "Use huge thumbnails" is always unchecked after I reopen the option window.
XnView 1.90 <x>
Some problems in Option's window.
Nelson
marsh
Re: Some problems in Option's window.
The idea is to allow both include and exclude functionality at the same time (which currently isn't possible with v.1.82.4).Nelson wrote: 2. In "Browser->File List->Items displayed".
Nelson
Thanks for answering.marsh wrote:The idea is to allow both include and exclude functionality at the same time (which currently isn't possible with v.1.82.4).Nelson wrote: 2. In "Browser->File List->Items displayed".
Then there should be some tips.
Otherwise, users don't know what they are and don't know which is for include/exclude.
Dreamer
Perhaps "Please choose which items are shown in the browser" should be changed, maybe something like this could be added "... (uncheck to exclude)".Nelson wrote:Thanks for answering.marsh wrote:The idea is to allow both include and exclude functionality at the same time (which currently isn't possible with v.1.82.4).Nelson wrote: 2. In "Browser->File List->Items displayed".
Dreamer
Nelson
This bug still exists in Alpha2.Nelson wrote: 3. In "Browser->Thumbnail->Appearance".
And this topic should be at Alpha - Bugs group.
Can somebody help to move it to there?
No, 'Use huge ..." will be checked only if your thumbnail size is greater than 320x320Nelson wrote:This bug still exists in Alpha2.Nelson wrote: 3. In "Browser->Thumbnail->Appearance".
Olivier_G
Works in Beta 5.Nelson wrote:Uncheck "Show Most Recently Used Files in File menu", the "Show Most Recently Used Files in submenu" is grayed. But when I reopen the option window again, it is not grayed and is enabled.
I don't find this feature straigthforward -> a better solution is needed, IMO.Nelson wrote:In "Browser->File List->Items displayed". There are two "Custom files" at the bottom.
I think it shouldn't be automatically unchecked, because:xnview wrote:No, 'Use huge ..." will be checked only if your thumbnail size is greater than 320x320
- The user decided to check it (for whatever reason).
- He may want to switch frequently between small & huge thumbnails and checking this regularly would just be a pain in the ass.
Olivier
