Difference between Fit to desktop and Best Fit to desktop
klumy
Post by klumy »
What are the differences between this 2 options
if you want to set a new wallpaper
XNView 1.91.5
Windows XP SP3
ckv
Post by ckv »
That's simple. "Fit to desktop" is same as the fit to desktop in windows (windows does the scaling), but in "Best Fit to desktop" XnView pre scales the picture (probably with better algorithm).
