Options > Toolbar: Button for choosing file
In "Options > Toolbar" the user has buttons ">>" for choosing a command file and an icon file. I think instead of ">>" the button should be labeled with "..", which is XnView standard.
In this context I wonder whether we should introduce symbols for choosing files. A small button with a folder symbol might be clearer than just "...". Sure enough this would affect various location throughout the XnView dialogs, e.g. Batch Convert.
V 1.90 A1
V 1.90 A1
• Hi !
- It's indeed incoherent to use either "..." or ">>" for the same purpose…
- IMOH, "..." could do the trick if used for all, but it might use bigger characters. The dots are really tiny and hard to spot…
- In the experimental French DLLs, I use "• • •" (#149) which is supported by the current default font.
- I agree that a small bitmap should look much better, not sure it fits @ all locations, though…
Only to write "• • •" I ought enlarge a bit some button-controls which are too narrow
G.
Wrong thread !
—> marsh
Hi B. !
- I guess you are not in the right thread, this one is to open a folder in order to choose an icon,
not about the positions of the icons.
- The right thread is THERE
KR
Related threads.
Changing the arrows mentioned in other topic would be enough. I think ">>" is correctly used here for inserting commands/icons into toolbar.
Re: Related threads.
I disagree. The buttons in this context are used for selecting a filename (instead of typing it), for this case the "..." is (sort of) XnView standard.marsh wrote:Changing the arrows mentioned in other topic would be enough. I think ">>" is correctly used here for inserting commands/icons into toolbar.
Yes, I agree with Helmut.helmut wrote:I disagree. The buttons in this context are used for selecting a filename (instead of typing it), for this case the "..." is (sort of) XnView standard.marsh wrote:Changing the arrows mentioned in other topic would be enough. I think ">>" is correctly used here for inserting commands/icons into toolbar.
Dreamer
Re: Options > Toolbar: Button for choosing file
Beta 5 is like this.helmut wrote:I think instead of ">>" the button should be labeled with "..".
I'm not convinced by the use of larger dots or even a folder bitmap as "..." is quite standard -> closed (in Hack'n Slash style...
Olivier
Lovely symbol…
• Olivier, you are a too fast “Closer” !
- Before to bury that topic, please just watch that we got in TC now (incredible ! ) for the “Browse…” symbol :
• Isn't it quite cute, even lovely ?
- Humm… This one is not the standard (which is black and white), I improved the drawing “a bit”.
However, it's here as a 16² pic, so, usable.
nightflyer
Re: Lovely symbol…
Hi Claude,
Ok, ok... I move it to postponed: but it would require a really great bitmap one to improve this!
YES!Clo wrote:Olivier, you are a too fast “Closer” !
Olivier
Great ?
• If you find a “great” bitmap as 16² for this, I eat my sunhat !
Re: Lovely symbol…
It looks great! The larger "..." is also nice.Clo wrote:“Browse…” symbol :
• Isn't it quite cute, even lovely ?![]()
A try?
• Ah ! Glad to hear a wise man, finally !
• It isn't a big deal to use this bitmap in the programme, Pierre might give it a try… It's only 822 bytes as BMP 24 BPP…
