How about Microsoft Fax Document Format (.AWD)?
Sirichoke
Post by Sirichoke »
Please make XnView support for Microsoft Fax for Win 95 format (.AWD - At Work Document).
Re: How about Microsoft Fax Document Format (.AWD)?
Sirichoke wrote:Please make XnView support for Microsoft Fax for Win 95 format (.AWD - At Work Document).
Yes, i would like, but i have no specs on it.
Sirichoke
Hope this help
Post by Sirichoke »
Hope this help...;)
Cut from http://www.faqs.org/faqs/graphics/filef ... faq/part3/
Subject: AWD - Microsoft Fax At Work Document
Type: Bitmap
Extension: AWD
Version:
Compression:
Color Depth:
Maintainer: Microsoft Corporation
Specification:
AWD is an OLE compound object file that stores bilevel facsimile data.
The compression algorithm used by AWD is not published, but it is based
on CCITT Group 4. The format of OLE compound object files also seems not
to be published, but there much OLE information available:
http://www.microsoft.com/oledev/oleocx/ole11.htm
OLE Control and Control Container Guidelines, Version 1.1
Re: Hope this help
Sirichoke wrote:Hope this help...;)
No sorry, i know it.
LittleChild
Just an example
Post by LittleChild »
There are a handfull of apps available (also as trial downloads) that can view/print/convert .awd files, among them ThumbsPlus and AutoImage. Just use one of them for a one-time conversion of all your .awd files into tiff/gif/png and that's it.
Post by Guest »
these uses a functionality from specfic DLL files..
try this page
http://support.microsoft.com/kb/q140980/
all dll files used to read/write/view is included
MAAD
Post by Guest »
another link
http://www.slipstick.com/fax/ntawdview.htm
sorry for double post
MAAD
Anonymous wrote:these uses a functionality from specfic DLL files..
try this page
But these DLL doesn't works on Xp
Post by Guest »
no it does.. i've installed it on XP and now i can view ART files easy.. and i have choise either to save into BMP or as ART..
MAAD
Post by Guest »
sorry for wrong reply..
yes it won't work in normal .. mode.. there the XP option (look at
Microsoft provides a conversion utility on the Windows XP CD. Look under i386\win9xmig\fax\awdvstub.exe. Run it with no command line arguments to get its options. Use the /c command-line switch to convert an AWD file to a TIFF file.
If you want to run Awdvstub.exe from your local machine, rather than from the CD, you'll also need to copy Faxtiff.dll.
MAAD
