Loading of JPEG files with option ICC profile turned on is extremly slow.
By the way - what about icc profiles in other file formats, for example in tiff? Will it be available in release?
V 1.90 <x>
Re: Loading of JPEG files with option ICC profile
Yes, it's normalsergo wrote:Loading of JPEG files with option ICC profile turned on is extremly slow.
Do you have such tiff?By the way - what about icc profiles in other file formats, for example in tiff? Will it be available in release?
Olivier_G
First, a screenshot to show that ICC option works and is great...
(Left=OFF, Right=ON)
(thanks to Phoebe for the samples)
Suggestions:
- Apply ICC conversion to thumbnails as well
- (I believe conversion is to sRGB display?) ...then skip sRGB->sRGB conversion: it won't slow down XnView
- If above works, makes ICC=ON the default setting
ICC conversion should also work for TIFF and even JPEG2000 and PNG => Pierre, I send you some JPEG/TIFF/PNG samples in sRGB and AdobeRGB for the same picture.
Suggestions:
Olivier
Olivier_G
Pierre, what's the status on all this for 1.90?Olivier_G wrote:- Apply ICC conversion to thumbnails as well
Olivier
ICC work for jpeg and TIFF, and i'll add icc support for thumbnail too for b6Olivier_G wrote:Pierre, what's the status on all this for 1.90?Olivier_G wrote:- Apply ICC conversion to thumbnails as well
Olivier_G
Olivier_G
