The list of formats supported shows .fit but when I try to open a .fit file, it just shows the a hex dump of the file. Do I need a plug-in?
Thanks
Al
Opening a .fit file
Re: Opening a .fit file
No, but please send me the file?adegutis wrote:The list of formats supported shows .fit but when I try to open a .fit file, it just shows the a hex dump of the file. Do I need a plug-in?
