Canon Makernotes
kurka666
Canon Makernotes
Post by kurka666 »
Hi
Will you support Canon Makernote EXIF fields in a future SDK?
http://www.sno.phy.queensu.ca/~phil/exi ... Canon.html
thanks
Re: Canon Makernotes
kurka666 wrote:Hi
thanks
Canon Makernote is supported, please send me a file if you have problem?
kurka666
Post by kurka666 »
oh - is it?
Do I need to do anything special to get the makernote fields?
Currently I am using the PGFL_EXIF_DATA.ItemsList[index].tag and PGFL_EXIF_DATA.ItemsList[index].value properties and it doesn't seem that I get any makernote fields. Shouldn't that be sufficient?
I have tested with both Powershot G3 and EOS 1D Mk II cameras.
Thanks
kurka666 wrote:oh - is it?
Thanks
Do you have them with XnView??
kurka666
Post by kurka666 »
Yes - I just sent you an email with some more details
kurka666
Post by kurka666 »
Hi
did you get the emails I sent you with the examples?
Henrik
