Can you make the 'File already exists' dialog, which shows when the user wants to copy/move some files bigger? On today screens, the thumbnails which shows there is very difficult to compare, in order to make a right decision. (Perhaps you can put the compare files engine there?...)
Perhaps you can make it to fit on screen?
TIA
A bigger 'File already exists' dialog
m.Th.
m. Th.
