<Moderator's note: This topic has been moved>
Pierre,
about grow of the db, would it be an option to apply the autovacuum pragma
sqlitedb.execsql('pragma auto_vacuum = 1');
instead of relying on the user's housekeeping? (if not: why: speed?)
btw: i found my thumbsdb to be now in the window's application data dir;
i would prefer to keep it relative (important: relative!) to my xnview's
program directory, just as before. Did i miss something?
Kind Regards,
klaus2
alpha forum topic "Database size"
Re: alpha forum topic "Database size"
Yes, speed, and you can use optimizeklaus2 wrote:<Moderator's note: This topic has been moved>
Pierre,
Now all data are stored in user directory, you can change it in option/Cachebtw: i found my thumbsdb to be now in the window's application data dir;
But why do you want it relative???
