This is a thread of the feature "multi page file".
I wonder, because I didn't enter any directory into the field "Directory".. but it created a PDF file anyway.
But where does it save it?
The button "Options" should be closer to field "Format ".
Will there be a toolbar button for feature "Multi page file..." in future?
V 1.90 <x>
thread about feature "Multi page file..."
andreasm82
My private (german) page www.energie-bewusstsein.de
andreasm82
If output file already exists, it overwrites it without any comment!
There should be at least a warning message if output file already exists.
While writing output file, xnview is instable and the whole system is blocked.
I can't open windows explorer or any other programs ...
converting window looks like this while writing output file:
(keine Rückmeldung) means no response. Windows thinks that the application has crashed because it doesn't response...
Furthermore, dialog elements should be disabled while writing output file!
Already…
• Without any output dir, the file is saved in its source folder.
• A button can be set already in 1.90 Alpha 2. Please, see the Options.
- However, you must provide an external icon for it. There is no icon-set yet (except my own test ones…)
• When the file exists already, we might choose the behaviour in an appropriate dropdown-list which is missing currently…
andreasm82
"Create" Button should be disabled as long as there are no entries in listbox.
Olivier_G
In Beta 5, with 'Multi-page file':
- XnView writes over a previous file without prompting/warning
- I agree that 'Options' button should be just near Format
- While creating a document, XnView interface is not updated (to check: maximize/minimize another window in front) -> a realtime progress-bar would be great (a simple timer-mouse symbol would be OK).
-> New
-> New
Olivier
marsh
Olivier_G
Fixed in Beta 6 (ie: dialog window appears).Olivier_G wrote:XnView writes over a previous file without prompting/warning
Other suggestions not implemented -> Postponed.Olivier_G wrote:- I agree that 'Options' button should be just near Format
- While creating a document, XnView interface is not updated (to check: maximize/minimize another window in front) -> a realtime progress-bar would be great.
Olivier
