hi,
i would like to enhance saturation during batch conversion. how can i do this?
thank you,
bye
Malcolm
enhancing saturation
Re: enhancing saturation
Regards. Pierre.
I'll add this function in a next release!Anonymous wrote:i would like to enhance saturation during batch conversion. how can i do this?
Regards. Pierre.
Phred
There continues to be a vast paucity of assistance for batch operations using NConvert, even after 19 years of patience.
The current/latest text file -help provides:
If anyone can work out from that line how that command can be used, it would be a magnificence added to the universe.
Anyone?
-hls h l s : Adjust Hue Lightness Saturation
Anyone?
Regards, PhredE
I think you could gain some insight into how to use the NConvert HLS option by experimenting on an image opened in XnView MP Image > Adjust > Enhance colors... and noting the HLS values displayed when you obtain the result you need...
It sems reasonable to expect that values obtained in XnView MP will produce a similar result in NConvert.
