- Bigger tag box. The box is too small to be checked easily.
- Hotkey to tag/untag. Because of the small tag box, a hotkey to tag/untag would be useful.
- Show all tagged files. Maybe you can add an item in the drop-down filter menu to show all tagged files, then users can easily to view/edit/untag the files they tagged.
More enhancements about tags
Nelson
The "tag" function is useful.
But I think it could be better.
Anika
Re: More enhancements about tags
To handle the tagged files it would be useful to filter, search and sort by tag.Nelson wrote:1. Bigger tag box. The box is too small to be checked easily.[/url]
look this thread: Tags: Position
look this thread: Tags: Menu itemsNelson wrote:2. Hotkey to tag/untag. Because of the small tag box, a hotkey to tag/untag would be useful.
Nelson wrote: 3. Show all tagged files. Maybe you can add an item in the drop-down filter menu to show all tagged files, then users can easily to view/edit/untag the files they tagged.
XnView 2.04, 2.13 Windows 2000 SP4 and Windows XP SP3 and Windows 7 64bit
Nelson
I'm discussing about the box size, but the thread discusses about the position.Anika wrote:look this thread: Tags: PositionNelson wrote:1. Bigger tag box. The box is too small to be checked easily.
I think they are different.
Pity, the hotkey T can't work nowAnika wrote:look this thread: Tags: Menu itemsNelson wrote:2. Hotkey to tag/untag. Because of the small tag box, a hotkey to tag/untag would be useful.
Anika wrote:To handle the tagged files it would be useful to filter, search and sort by tag.Nelson wrote: 3. Show all tagged files. Maybe you can add an item in the drop-down filter menu to show all tagged files, then users can easily to view/edit/untag the files they tagged.
And there is one more thing that needs to be noticed.
After you tag some files, the rename (and copy, and move, and maybe etc.) operation works for the tagged files, not for the selected files.
I think there are two drawbacks about this situation.
- Some users may not notice that and make wrong operation. For example, they rename the tagged files, but they would like to rename the selected files instead.
- Some users (like me) don't know these operations have different behaviors when they tag files, and then they don't know what they can do when they tag some files.
Anika
2. tag/untag
I just noticed that the space key has the tag/untag function. Ctrl+R untags all files. What should happen if some of the selected files are tagged and some are not? By now with the space key the tagging is inverted. The menu point "Tag current (T)" tags all selected files (while T does not work yet).
The behaviour is the same as if I select files whith right click in my file manager WinNC.net. The tagging fixes the selection. As soon as at least one file is tagged all actions refer to the tagged file(s). The selection by mouse (blue background) has only effect for tagging.
From this state of information there is no need/possibility to search by tag.
Any good idea? The feature has to be explained in the help and WhatsNew.
As far as I tested the tag function:After you tag some files, the rename (and copy, and move, and maybe etc.) operation works for the tagged files, not for the selected files.
Yes, but it's the tag feature... If you have some tagged files, so i use them, else i use selected files (If tag sytem doesn't work like that, i don't see any advantage to tag files????)Nelson wrote: And there is one more thing that needs to be noticed.
I think there are two drawbacks about this situation.Any good idea?
Perhaps i can ask the user before any action? What do you think?
Nelson
Maybe show a dialog to tell the user at the first time ?xnview wrote: Yes, but it's the tag feature... If you have some tagged files, so i use them, else i use selected files (If tag sytem doesn't work like that, i don't see any advantage to tag files????)
Show a dialog to let them know they are working on the tagged files.
And user can choose "Don't show this dialog again".
Anyway, the tag function is useful.
But it would be better if there is a "Show all tagged/untagged files" function.
Olivier_G
In Beta 5:
1. Bigger tag box: There was a bug with tagbox check/uncheck which has been solved.
2. Hotkeys T/Space work.
3. Menu View>Filter by>tagged files works.
.. There is now a dialog to choose 'tagged files' or 'selected files' for operations.
-> closed
-> closed
Olivier
