Archive support - viewer fullscreen bug
Dreamer
Post by Dreamer »
- enter zip archive
- go to any image
- switch to viewer
= switching between images works good here
- switch back to browser
= you are in "C:\DOCUME~1\<user>\LOCALS~1\Temp\" folder
= images in this folder are also (probably) not removed if you leave archive
V 1.90 Alpha
Dreamer
Same…
:) Hello !
• Confirmed, same here. Switching the modes works OK, though.
- A similar problem existed in TC : when some archives (SFX-EXE) were opened, and contained a *.CAB you opened too, then closing via “• •” made you landed in the temp. directory… The workaround was to use the "Refresh" key (F2 there) to close and go back to the primary archive content…
- However, TC doesn't use always the system¦User temp. dir., the temp location is configurable at will.
- Just a remark, I don't know if that does matter or not…
:mrgreen: KR
Dreamer
Re: A: Archive support - viewer fullscreen bug
Post by Dreamer »
Dreamer wrote:- enter zip archive
- go to any image
- switch to viewer
= switching between images works good here*
= you are in "C:\DOCUME~1\<user>\LOCALS~1\Temp" folder
Not fixed in beta 1.
* - now even this doesn't work
Moving to " Confirmed/Reproduced".
Dreamer
