Capture the allocated area of the screen
BraVo567
It would be desirable to have an opportunity of the capture, the allocated area of the screen.
Re: Wish: capture, the allocated area of the screen.
Not sure what you mean:BraVo567 wrote:It would be desirable to have an opportunity of the capture, the allocated area of the screen.
- You can capture (=make a screenshot) of the desktop or a specific window using menu 'Tools->Capture...'
- You can copy the selected area in an image to the clipboard using menu 'Edit->Copy' or Ctrl+C key.
