noticed a minor bug while I had my laptop connected to our corpnet at work. I access a network drive as part of a MS Windows network. When I select a folder from the browser window (the one on the right side of the screen not the folder window) I get the following error:
"Network Name" is not accessible. You might not have permission to use this network ressource. Contact the administrator of this server if you have access persmssions.
The list of servers in this workgroup is not currently available.
OK
However, when I click ok, it shows me the folder content anyway. It takes about 30 sec for this message to appear. It works fine when I use the folder list on the left side.
Just a curious behavior. BTW, I'm running Win XP Pro.
Thanks! Great Software!
Matt
Minor bug in the folder view when in a networked environment
Matt
