Diaporama and animated gifs
Username
Post by Username »
Hello
I have a problem : the animated GIFs do not move in the diaporama mode.
Can you help me ?
Thank you
Re: Diaporama and animated gifs
Username wrote: I have a problem : the animated GIFs do not move in the diaporama mode.
Can you help me ?
Right, slideshow doesn't show animated gif
negtrick
Post by negtrick »
With the 2.25 version on Seven diaporama shows animated gif but do not loop them... I search a solution.
Does everybody knows a viewer that plays diaporama with animated gif? I have Irfanview but only one transition effect (fade) and some gif play anormally...
Is-it possible to modify XNview to do it? I can make a donation for that...
Regards.
negtrick wrote: With the 2.25 version on Seven diaporama shows animated gif but do not loop them... I search a solution.
You would like that animated gif with a loop, and you use key for next file?
negtrick
Post by negtrick »
I run diaporama with all transition effect with switching to the next file automatically by selecting files in the tree. Sometimes, I use navigation keys: left or right to foward or backward, space to play/pause automatic switching. The diaporama opens gif files but the animation of the gif file just runs one time and freezes.
I would like gif animation loop as if I open the file separatly.
Regards.
Je lance le diaporama en sélectionnant les fichiers voulus dans l'arborescence. Je choisi le passage automatique au fichier suivant mais il m'arrive d'utiliser les touche de navigation: flèches droite et gauche, espace pour faire play/pause. Les gif s'affichent mais ne bouclent pas comme c'est la cas quand on ouvre un fichier gif dans un navigateur ou via n'importe quel logiciel. J'aimerais que les fichiers gif s'animent dans le diaporama comme si on l'avait ouvert séparément, c'est à dire en bouclant indéfiniment.
J'ai écrit en anglais pour respecter la langue d'origine du post ^^
Cdt.
