View 2 images side-by-side in fullscreen mode?
TsunamiZ
Post by TsunamiZ »
Is there a way to view 2 images side-by-side in fullscreen mode? Thanks.
Re: View 2 images side-by-side in fullscreen mode?
TsunamiZ wrote:Is there a way to view 2 images side-by-side in fullscreen mode? Thanks.
Do you have tried 'Compare'?
TsunamiZ
Post by TsunamiZ »
that's not fullscreen mode though. and i can't browse through files using the arrow keys that way. users have to constantly select 2 files. i wish for a feature that is an option in fullscreen mode to display 2 files seamlessly side-by-side like a book. helpful when viewing certain images that are book scans or are broken into 2 images. is that possible?
Sorry not possible
TsunamiZ
Post by TsunamiZ »
check out this program that can:
http://www.geocities.com/davidayton/CDisplay
"...Automatic page sizing: none; fit to screen, fit to width of screen, fit to width of screen if oversized, display at specific height, or display two pages. Resizing uses Lanczos interpolation for best picture quality..."
It does
—> TsunamiZ
:) Hello !
• I gave a quick try to that soft : Right, it does that you wish.
• However, it's very limited at other features (formats…) and not localisable normally :wink:
- Moreover, the Lanczos' algo is not necessarily the best in all cases, there are old threads about this here…
• But this is another story… Image
:mrgreen: KR
TsunamiZ
Post by TsunamiZ »
thats just to show how it can be some and maybe give xnview some ideas :)
TsunamiZ
Post by TsunamiZ »
any progress?
