Renaming and deleting folders
lindsaydaniels
Post by lindsaydaniels »
suggested addition to the program - allow it to rename, move and delete folders - it doesn't seem to be able to do that
Re: renaming and deleting folders
lindsaydaniels wrote:suggested addition to the program - allow it to rename, move and delete floders - it doesn't seem to be able to do that
Thanks for the suggestions. Renaming folders is possible, already, try selecting a folder in the right file pane and then menu 'Edit->Rename' (or context menu or 'F2' key).
As you write, copying and moving is currently not possible, see Drag-n-drop, Rename with search-n-replace.
lindsaydaniels
thanks! i learned this after sending my suggestion. it also deletes in the right file pane
alex
Post by alex »
i wish that would work in the LEFT browser panel, too !
i cant even use the function "move to" on folders in the right panel.
keep it up.
Post by Guest »
alex wrote:i wish that would work in the LEFT browser panel, too !
keep it up.
is it fixed ?
i still cant del/move/copy any folder in the left browser panel (dir tree).
v1.74RC4
keep it up.
is it fixed ?
v1.74RC4
No sorry!
alex
Post by alex »
keep it up.
is it fixed ?
v1.74RC4
No sorry!
i still think those are important features. please try to implement them in the future.
bigup xnview.
