Ignored stated extensions…
—>Pierre
:) Hello Pierre !
• A small request unanswered for ages that you can see HERE.
• I tested again by stating WLX in the Options >> Displayed items, the *.wlx is not recognized at all, and gives the damned well known error message… :(
- The box "Recognize only by extension" (or so…) is NOT ticked,
so the file-headers might be parsed, and the files displayed as DLLs, that they are…
- Subsidiary question : Should it be possible to use a wildcard in the Options for the customized formats, i.e. here : W*X ?
TIA to give a glance on that issue…
:mrgreen: KR
XnView 1.90 <x>
Re: Ignored stated extensions…
Clo wrote:—>Pierre
:) Hello Pierre !
Yes, but currently i use only DLL extension to extract icons
ouistiti
Post by ouistiti »
:arrow: xnview
That's why we are asking for the possibility to add other extensions (like wlx, wcx,wfx,...)
TIA
Friendly
Paul
1,77245385090552...
= DLL
—> Pierre
:) Hi !
• Is it so complicated to teach the programme that *.W*X = DLL ?
• Maybe simply some INI entry to state the correspondence ?
- This is not the only case; i.e., in the good SQX packer (plugin TotalSQX in TC by Lefteous),
there are also DLLs disguised as the *.ZZL extension !
:mrgreen: KR
