is it possible to use the
noise funktion like in Xnview...
Add uniform noise
Add gaussian noise
in the 'rezise' function
possible to use the
Lanczos parameter ?
or only 'bilinear'
Marie
Add noise
Re: Add noise
Currently these fonctions are not available, but if you want them, i can add them to gfleMarie K. wrote:is it possible to use the
Add uniform noise
Add gaussian noise
You have GFL_RESIZE_LANCZOSin the 'rezise' function
possible to use the
Lanczos parameter ?
or only 'bilinear'
Re: Add noise
xnview wrote:Currently these fonctions are not available, but if you want them, i can add them to gfleMarie K. wrote:is it possible to use the
Add uniform noise
Add gaussian noise
?You have GFL_RESIZE_LANCZOSin the 'rezise' function
possible to use the
Lanczos parameter ?
or only 'bilinear'
only declared in the bas - File !!
Public Const GFL_RESIZE_QUICK = 0
Public Const GFL_RESIZE_BILINEAR = 1
GFL_RESIZE_LANCZOS ?? Number ??
Re: Add noise
#define GFL_RESIZE_QUICK 0
#define GFL_RESIZE_BILINEAR 1
#define GFL_RESIZE_HERMITE 2
#define GFL_RESIZE_GAUSSIAN 3
#define GFL_RESIZE_BELL 4
#define GFL_RESIZE_BSPLINE 5
#define GFL_RESIZE_MITSHELL 6
#define GFL_RESIZE_LANCZOS 7
