Tag and Compare functions
Nelson
Post by Nelson »
When I tag some files but only select ONE file, the "Compare" menu is disabled.
But when I select more than one file (whether they are tagged or not), the "Compare" menu is enabled and the tagged files (not the selected files) can be compared.
My point is:
The "Compare" menu should be enabled when I tag more than one file, whether I select more than one file or not.
Right?
Re: Tag and Compare functions
Nelson wrote:When I tag some files but only select ONE file, the "Compare" menu is disabled.
My point is:
Right?
Ok, i'll check
Olivier_G
Post by Olivier_G »
Works fine in Beta 5 -> closed.
Olivier
