strip " from browserpath?
loth
Post by loth »
hi all,
in browsermode:
if the path, the user copy+pasted is like "P:\pics\Comix\M\Maroto, Esteban"
(with the ") then xnview doesnt browse/show this folder. only, if i dont use the "
i would like to consider, that xnview could strip the " itself (or ignore them?), so that the user doenst have to manually remove/strip them.
only for the lazy guys, which don't type but only copy+paste text :)
any suggestions?
loth
Re: strip " from browserpath?
loth wrote:hi all,
in browsermode:
any suggestions?
Ok :-)
marsh
Post by marsh »
Done. It works in Alpha3.
loth
Post by loth »
marsh wrote:Done. It works in Alpha3.
indeed, thanks, but there is another small issue.
if the path is "C:\foo\bar " (space at the end of the path which comes from the clipboard) or " C:\foo\bar" (space at the beginning) then xnview ignores this path as well.
please strip all useless/illegal chars, this would be great.
