Possible to view recycle bin?
TsunamiZ
Is it possible to view recycle bin in XnView? If so how? Thanks.
Re: Possible to view recycle bin?
No it's not possibleTsunamiZ wrote:Is it possible to view recycle bin in XnView? If so how? Thanks.
TsunamiZ
darkfader
Can you can do this in fact.
Run "cmd" and type "dir /b /od /a C:\RECYCLER" to see recycle folders for different users. The last directory is probably yours.
Press Alt+Space and then P and then enable QuickEdit Mode.
Select the directoryname and press Enter to copy it to the clipboard.
Paste it in XnView and add "C:\RECYCLER\" in front of it.
Don't forget to add it to your favorites.
I've tried to do it by editing the ShellFolder Attributes of {645FF040-5081-101B-9F08-00AA002F954E} but it didn't seem to work since it probably expects a physical pathname.
TsunamiZ
it doesn't work right tho...it doenst show the actual folder and file names in the recycle bin...and when u delete the files from it...it leaves files/folders named "dc1" in the recycle bindarkfader wrote:Can you can do this in fact.
Paste it in XnView and add "C:\RECYCLER" in front of it.
