variable JPG compression and Info text in EXE slideshows
pavel1
Post by pavel1 »
I have two suggestions for possible settings of EXE slideshows.
1. In window mode (Fixed size option) images have quite strong compression - JPG artifacts are sometimes visible - even if 'Use high quality' option is checked. I would be fine to have a possibility to set a degree of the JPG compression.
2. Information text is not displayed in window mode. I understand that it is difficult to place it properly but it could be displayed in some optional fixed-sized border or other suitable area.
Pavel
[/url]
