1. XnView crashes when run with user rights and cache is enabled. xnview wants to write in "programs files\xnview\cache" but must write in "documents and settings\user\application data\xnview\cache" or some like this
2. XnView ignores popup key on keyboard (mouse right click works) in browse and view mode
Bugs: GPF with user rights, popup key does not work
Re: Bugs: GPF with user rights, popup key does not work
Alexey et al,
Thank you for these defect reports.
Just tried this out with a guest user on Windows XP SP1 and yes, XnView crashes right after the start.alexey galkin wrote:1. XnView crashes when run with user rights and cache is enabled. xnview wants to write in "programs files\xnview\cache" but must write in "documents and settings\user\application data\xnview\cache" or some like this
Before reading your post I didn't even know that this key exists and what it is for. You're right, again, the popup key (located at the bottom right, next to the CTRL key) does not work in XnView. When pressing, nothing happens. Instead, the context menu should appear.alexey galkin wrote:2. XnView ignores popup key on keyboard (mouse right click works) in browse and view mode
