sharpen (or other Function) only in a part of a picture
Pierre St
Post by Pierre St »
hi
i want to sharpen only a small rectangle .. not the whole picture...
how can i define this part of the picture ?
and then... use the 'normal' sharpen function ?
regards
Pierre St
Re: sharpen (or other Function) only in a part of a picture
Pierre St wrote:hi
Currently it's not possible...
MaierMan
Post by MaierMan »
not possible means:
do a workaround ;)
a) Get the rect into another picuture (crop-copy or something like this)
b) Apply the filters (i.e. sharpen)
c) bitblt the stuff back
alternative:
Develop your own filter (i.e. sharpen) implementation that works like you desire. ;)
