GPF when rotating multiple marked images
rederik
Post by rederik »
When marking multiple images and losslessly rotating them via context menu, the program crashes. Always and repeatedly. "unknown software exception (0xc000008e) at "0x004ffaa6".
Tried deactivating cache - no effect. Happens with left, right and automatically (Exif) rotation. Using normal menu doesn't help either. Using "Dialog" doesn't help, too. Marking one picture and then rotating works - it's the multiple marking (shift + leftclick) thing that crashes the program.
Win XP with SP2 and XNview 1.82.4 (Mar 3 2006). German language version
Who can help me - without this basic feature Xnview is only of limited use.
Thanks a lot,
Erik
Re: GPF when rotating multiple marked images
rederik wrote:When marking multiple images and losslessly rotating them via context menu, the program crashes. Always and repeatedly. "unknown software exception (0xc000008e) at "0x004ffaa6".
If you try on a single file, it works??
Post by Guest »
No - still crashes.
(I was in holidays - therefore I answer now)
Anonymous wrote:No - still crashes.
So lossless rotation doesn't work for you with one or more files! It's strange.
Which OS? Perhaps you could send me a jpeg that you try to rotate?
And by using the lossless dialog, it works?
Post by Guest »
Its any (!) Jpeg (pictures, ...)
The OS is Windows XP, SP2. Every update. I think it must have sthg. to do with my computer. Perhaps the graphic card or its driver, as e.g. a 3D program also crashes.
Anonymous wrote:Its any (!) Jpeg (pictures, ...)
Your files are not in read only?
Very strange, someone with the same problem?
