Adjust Zoom if X/Y DPI are different
LCardinali
Post by LCardinali »
I have a TIF like this:
width=1728
height=1155
pixel per Inch=200 x 100
when I open it with xnview I view an image distorted.
If I set the option: aption>View>"Adjust Zoom if X/Y DPI are different" , when I open the image is distorted, but if I click on "zoom Out" just one time it becomes normal.
I need to open the image already nomal , without do any "click".
instead when I open it with xnview I view an image with pixel per Inch=200 x 200 is always OK.
thaks
Re: Adjust Zoom if X/Y DPI are different
LCardinali wrote:I have a TIF like this:
width=1728
height=1155
Which version?
lcardinali
Post by lcardinali »
1.66
lcardinali wrote:1.66
Please use the 1.70
LCardinali
it works, but with version 1.70 I have another problem:
with version 1.66 I select an area and with a single click I zoom in the selected area.
with version 1.70 I select an area and I get zoom in with [ctrl] + click
How can I work in version 1.70 like in 1.66 ( with a single click instead of [ctrl] + click ) ?
thanks
LCardinali wrote:it works, but with version 1.70 I have another problem:
thanks
Ok, i'll add an option for that..
