Assume I have a big picture which is shown in original size in XnView.
Because it is so big large parts are only visible when I drag the sliders
on the right side and at the bottom.
However I have seen some other smarter ways of "scrolling" in other
image viewers:
I click with the left mouse inside the picture - hold the mouse key down
and drag the whole picture up to the desired direction.
Is this possible in XnView as well ?
Which setting do I have to enable to have a scrolling option in this way ?
Scroll down by inside dragging not by slider possible ?
pstein
Re: Scroll down by inside dragging not by slider possible ?
So you means a pan feature, yes i must add itpstein wrote:Assume I have a big picture which is shown in original size in XnView.
image viewers:
Olivier_G
Yes. Check or change the setting in Options>View>Keyboard/Mouse for 'Move picture'. It should be on either Left or Right Button.pstein wrote:Is this possible in XnView as well ?
=> you can also directly try Right (or Left) Mouse Button and move the image.
Olivier
