Background on Thumbnails
AndyPC
Post by AndyPC »
How do you set the background on thumbnail images. I keep on getting a black background when I want white.
Nikolay Raspopov
Re: Background on Thumbnails
Post by Nikolay Raspopov »
AndyPC wrote:How do you set the background on thumbnail images. I keep on getting a black background when I want white.
Same question.
Use canvas resize
SyntaxError
Example for white background with CanvasResize
Post by SyntaxError »
I try to change background thumbnail with GFlax to white but it does not work :
.LoadThumbnail File, Px, Px
.ResizeCanvas Px, Px, RGB (255,255,255)
Could you give one example?
Cheers :D
David
Re: Example for white background with CanvasResize
SyntaxError wrote:I try to change background thumbnail with GFlax to white but it does not work :
But you can't resize the canvas if the thumbnail has already this size??
jpfumoleau
Post by jpfumoleau »
Same problem even different sizes between LoadThumbnail and ResizeCanvas.
jpfumoleau wrote:Same problem even different sizes between LoadThumbnail and ResizeCanvas.
If you use LoadThumbnail, you have only the picture!
