XnView right click thumbnail menu
pivot
Post by pivot »
Greetings!
I installed Xnview earlier on windows xp 32bit and I got this neat feature where I could right click on my images and see a thumbnail of the image in the menu and even perform fast convertion to different image formats.
When my win32 crashed and I had to use the 64bit version I had installed earlier I also installed xnview, though this time I didnt get the right click menu. Ive looked everywhere and it's gone. How can I activate it? Is there some settings that I have to activate?
Aokromes
Post by Aokromes »
Sorry for you, but there is no x64 context-menu yet. http://newsgroup.xnview.com/viewtopic.p ... hlight=x64
Post by Guest »
Ah.... tnx
Post by Guest »
I just installed windows xp 32 bit again, and of course xnview was the first thing to download. I cannot get the content menu to work though. No neat thumbnails in the right click menu, no neat easy-access convert to meny. Nothing. I've searched all over the options, and the forum here, and I cannot figure it out. Latest version of Xnview, full version of course, not the zip - the .exe.... Whats wrong??
pivot
Post by pivot »
that was a post by me...
pivot
Post by pivot »
Never mind. I found out that it was a separate plugin now... I tend to ignore sticky posts. They often contain needless info in other forums ;)
