Export feature suggestions
Dreamer
Post by Dreamer »
- keyboard shortcut
- "always use export when saving files (with save/save as icon / ctrl+s / ctrl+shift+s shortcut)" - this would be better, because there is no "good" shortcut free
- use auto-size - b/kb/mb, not only bytes, it would be clearer
- initial focus should be on format, not color mode, it would be easier just to select format with arrows, press Enter and then Enter again to save
- maybe also "automatically select source format for export"
Dreamer
Re: Export feature suggestions
Dreamer wrote:- keyboard shortcut
Ok, thanks for your suggestions...
Dreamer
Post by Dreamer »
Another one:
- add export button to Save/Save as dialog, maybe with option suggested above, like this:
[Export] [x] Always open Export dialog when saving files
Dreamer
