CTRL+D (for opening the dialog 'Description') doesn't work for one or more pictures that are shown in a search result. The view (F8 to F11) makes no difference. I'm using version 1.70.4
I hope you can fix it so I don't have to go through rightclick -> description.
Bye,
Anika
CTRL+D doesn't work in search result [bug]
ckit
Re: bug report: CTRL+D doesn't work in search result
Ok, i'll fix it.Anika wrote:CTRL+D doesn't work for one or more pictures that are shown in a search result. The view (F8 to F11) makes no difference. I'm using version 1.70.4
