A: Find similar results dialog too large.
marsh
Post by marsh »
Currently, the comparison dialog (results) for 'find similar' will not fit 1024x768 (lower buttons are not visible). Ideally, I think this dialog should be resizable like the other comparison dialog.
Nice here…
—> marsh
:) Hello B. !
• Can you see missing buttons below in the French dialogue ?
—————— Image
- 1024*768… It's indeed with a language DLL, here is the version with a narrow font.
- It seems correct too with a normal font (Tahoma, 8, normal)…
- The English speakers might request a DLL, I guess … :P
:mrgreen: KR
marsh
Wrong dialog
Post by marsh »
Clo wrote:—> marsh
:) Hello B. !
Not that dialog. :) I'm talking about the results dialog after it. It probably isn't finished, but I wanted mention it anyway. ;)
Not precised…
:) OUPS ! I will ckeck this one too, but it's possible that in French I fixed up this…;)
:mrgreen: KR
Same---
:) Done…
- If you mean the [Previous] [Next] [Stop] buttons, they are displayed OK here …
- I'll avoid a screen shot 'cause the box is rather huge ! :D
- So, I persist : English DLL ! :wink:
Note : Just to test, you may get the French DLL HERE…
:mrgreen: KR
marsh
Re: Same---
Post by marsh »
Clo wrote::) Done…
Using large fonts is what causes dialog to grow.
Not only the size…
:) Hi B. !
• I meant : Using exactly the same narrow font than above ! It's “Zurich CN BT”, size 8, normal.
- It produces the smallest screen shots still viewable…
- With a usual font like Tahoma 8, normal, the dialogues are much more large at width and height,
although the height of the characters be the same…
- This is a feature when using C+ … With Delphi, this doesn't occur, the size of the box doesn't follow the font, because each "object" may have a different font-type (and also size, colour, style, font-weight…)
:mrgreen: KR
Olivier_G
Post by Olivier_G »
'Duplicate results' window is 731x665 in Beta 5 and automatically moved to be within screen dimension -> 'closed'.
Olivier
